ThreadX tickless mode, can't get into Sleep mode
I have problems in getting this working. I moved from FreeRTOS to Azure RTOS, and I found out that in general there's lot less information on this RTOS. So I've been looking into the few resources, but I'm afraid I'm missing some important points. Ar...
paolog by Senior
  • 5567 Views
  • 5 kudos
Timer PWM DMA Pulse generation STM32F303
Hi, My aim is to generate a pulse sequence using the PWM timer and DMA analogue to Stm32 custom signal generation using pwm and dma with a STM32F303 on RTX5 RTOS. I need Pulsefrequency with max. 500khz, i use the STM32F303RCTx with PA2 as output Here...
pedahl by Associate II
  • 3051 Views
How to port X-CUBE-TCPP to STM32G0B1RE
Hello Everybody,I sucessfully included the X-CUBE-TCPP software expanison onta a NUCLEO-G071RB Board.After some inital tests we decided to switch to the NUCLEO-G0B1RE Board for more flash as the Getting Started PDF (https://www.st.com/resource/en/use...
VH by Associate
  • 2481 Views
Resolved! STM32F407 LWIP returning data to client
I previously posted here when I was having issues with my STM32F407 board that I have configured as a HTTP server.https://community.st.com/t5/stm32-mcus-products/where-to-find-lwip-incoming-payload-data-for-webserver/m-p/640137This is a follow-up pos...
Build gnu-tools-for-stm32 repo in Windows
I downloaded gnu-tools-for-stm32 repo to a Windows 10 machine. I have mingw64 installed.I want to study arm-none-eabi-objcopy with a view to extracting bin files for internal and external flash from an elf in a self-contained utility.When I navigated...
DRega.1 by Associate III
  • 2340 Views
STM32G474 FMAC for 3p3z controller
Hi all,I am trying to study the buck converter program provided by ST for the STM32G474 discovery kit. From previous study, I know that buck converter uses the 3p3z (3 poles 3 zeros) structure to calculate the current output, as shown in the figure b...
OFN_1-1704956047725.png OFN_0-1704955992301.png OFN_2-1704956342348.png OFN_3-1704956380277.png
OFN by Associate II
  • 2917 Views
Resolved! Disable Sink and Sorce at Startup DRP1M1
  Hello,I am using the NUCLEO-G071RB and the X-NUCLEO-DRP1M1 with the X-CUBE TXPP Software Bundle.I created my project via the instructions from https://wiki.st.com/stm32mcu/wiki/STM32StepByStep:Getting_started_with_USB-Power_Delivery_Dual_Role.Ever...
VH by Associate
  • 2254 Views
Resolved! Ethernetif.c in STM32f4 cube FW_F4 V1.28
Hello,I've read several forum posts commenting on the STM32 HAL management of LWIP, particularly ethernetif.c and trying to understand the interrupt driven zero copy examples. For reference in my application I do not use RTOS.After updating cube, and...
###### by Senior II
  • 3789 Views
  • 5 kudos
