2023-11-23 3:59 AM
I am currently trying to implement a bootloader that runs from the internal flash and performs the following functions:
1. copy application binary file to the SDRAM ( 0xC0000000)
2. Jump to main application.
So far I can copy the binary from the external flash to the SDRAM but when I try to jump to the SDRAM I am getting a hard fault error.
I have configured the MPU region to enable all access but I get the same result.
There are 2 points that are for me not clear:
- Does the SDRAM application have to be compiled with a specific linker configuration?
- Do I have to de initialize all the peripherals?
2023-11-28 10:38 AM
Hi CFranco
Your inquiry has been processed via the Online Support Center. We appreciate you taking the time to reach out to us.
Kind Regards
Joe WILLIAMS
STMicro Support
