2016-03-23 7:03 AM
in the stm32F4xx_hal_pcdm.c source file,
in HAL_PCD_IRQHandler the interrupt identified by USB_OTG_DIEPIN_XFRC is treated 2 times with the same code. Is it necessary? #hal-pcd-interrupt2016-03-23 9:03 AM
Hi guibert.benoit,
What do you mean by the interrupt identified by USB_OTG_DIEPIN_XFRC is treated 2 times with the same code? Could you please provide more explanation?Could you precise the CubeMX and the F4 HAL library versions are you using?-Syrine-We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
