STMF2 USB BULK IN/OUT Incomplete
Posted on February 26, 2016 at 23:29Hi,I'm working on getting a WinUsb working.  I have the device enumerating successfully.  However, when I try to send data on BULK OUT to the device or read data from BULK IN in both cases I see 'incomplete' on my...
chuck2399 by Associate II
  • 1129 Views
STM32CubeFx HAL library and Errata
Posted on February 26, 2016 at 10:52Hi CubeMX team,how do you solve microcontroler errata in HAL libraries ? It is possible to activate and deactivate the recommended workaround for different revision of microcontroller ? Petr #hal-library-erra...
STM32 CubeMX FATFS SDIO DMA hangs
Posted on February 20, 2016 at 03:24I have regular transfers working for read/writes. I am trying to get transfers working with DMA. I am using CubeMX 4.12.I set it up to have a dma request for both TX and RX (DMA2 Stream 3 and DMA2 Stream 6 respect...
dawime by Associate II
  • 1552 Views
stm32f0 nucleo , no receiving gps data
Posted on February 19, 2016 at 23:56 I really need help, This is my first time working with STM32 micro-controllers , I have a gps modulelocosys ls20031, at this point Im only trying to receive data from the gps and display on my terminal (realt...
SPI Flash+ Fatfs +STM32L0
Posted on February 23, 2016 at 08:32 Hi everybody, I develop file system on spi flash with FAtfs library.But i have a bit problem.My problem is f_getfree() function return 0 free cluster but all flash is free.The other fatfs function working...
CAN Loopback/Normal
Posted on February 22, 2016 at 16:58Hi Everyone, I'm trying to make the CAN working on my board, I use a STM32F103, with the HAL example, (cube F1). I did init as the example, I'm using the same pin PB8 & PB9. I calculate the baudrate to be at 250k...
yannick23 by Associate II
  • 2837 Views
