2013-03-23 1:28 PM
Hi all. I try to run audiopayback and record demo on F4 discovery board. When i upload precompiled binary (internal Flash mode) i hear from speakers 5 sec audio sample. Sound is not ''crystal clear'' but i think is correct.
But when i try to build on my own from inc/src folders using RIDE environ, i get stuck. Everything works fine LED's, IRQ, mems LIS itp. Even the audio sample plays through the speakers, but playback duration is 3 times longer then from precompiled binary. 15second, and it's very noisy. I check whole ssytem settings, PLL's, HSE itp. and everything is like should be, only playback speed seems to by incorrect. I miss something. Maybe any one got same problem before?? #wave-playback-discovery-stmWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
