2025-08-19 5:31 AM
I’m using a CAT24C32-D EEPROM. It works on our STM32F446-based PCB, but I can’t get it to work on our STM32U5A5-based PCB. I’m encountering both write and read errors. I’m using the same driver/library on both MCUs, and the hardware is identical except for the MCU itself.
What could be causing this? Why am I seeing these issues on the STM32U5A5 while the STM32F446 works fine? Any help would be appreciated.
2025-08-19 5:37 AM
You probably have a code bug. You should debug your program to find the source of the issue. Consider using a logic analyzer on the SDA and SCL lines to confirm what is happening on the bus.
2025-08-20 3:13 AM
Hello @inancmert
Any update on this thread?
