2025-02-11 12:38 AM
I am trying to use the internal DMA mode on USB_HS as a device mode. Can I get relevant USBD_LL_x api's which support it. And a sample example code which uses this DMA bus for configurations.
Thanks,
Srinath
2025-02-13 8:10 AM
Hi @S_Srinath
Are you using custom board with external PHY? AFAIK, we don't provide an example for High-speed operations in DMA mode on F4. You may check this article How to correctly setup your application to use USB... - STMicroelectronics Community.
