Resolved! stm32cubeide fatfs f_close FS_DISK_ERR
I have a board with stm32f407zgt6. I'm using freertos and fatfs. The board has a connection for an SDCARD, I'm using a 4GB SDCARD with fat32.For reading, F_open, f_read, f_close, everything works. When I use it to write, f_close takes a long time and...
MSilv.1 by Associate III
  • 8323 Views
  • 16 replies
  • 4 kudos
Resolved! LevelX FileX
Can anyone please confirm that LevelX and FileX can only be used with AzureRTOS. Everything that I have read indicates as such. Both only available when AzureRTOS is enabled as well as using CubeMX.Thanks in advance!!!
dsmail1 by Associate II
  • 1204 Views
Submit fixes for SVD files
Hi, I noticed several times that SVD files contain errors compared to what's documented in MCU RMs.The whole purpose of the https://github.com/stm32-rs/stm32-rs repository is basically to fix those errors and supply accurate SVD files for Rust embedd...
vinchatl by Associate II
  • 2371 Views
Resolved! mDNS on LWIP TCP server
I'm tying to setup TCP server using ethernet communications (Nucleo-F767ZI) and find that I can ping the board using the router allocated IP address but I'd like to do the same using Hostname. In STM32CubeMx .ioc file, under Network Interface Options...
jaykay by Associate
  • 6576 Views
