2020-06-12 8:09 AM
I'm starting out on a new project that requires two USB audio connections. Upstream connection should present itself as a host and downstream as a device.
Is there anything obvious that I'm missing that would preclude me from using the F407 in this application?
Kind regards,
AC
2020-06-12 4:47 PM
Nope. The STM32F407 has two USB peripherals. One can be a host while the other one is being a slave. One will be restricted to full speed, which for audio I can't imagine will be an issue.
