2011-09-01 1:37 AM
I have a problem with the ethernet controller DP83848 in combiantion with a STM32F107. I designed a PCB with these two components, I copied a part of the schematic of the STM3210C-EVAL board. I am using the RMII mode so I didn't connect the lines needed for MII. I know the software works because I tested it with the EVAL board. I suspect that the ethernet controller works because I can read and write to it. My problem is that I am getting a lot of false carrier sense errors from the ethernetcontroller so I think it has something to do with receiving data over ethernet. Does anybody have any experience with this problem or the ethernetcontroller? Thank You, Marco #metoo #stm32f107-dp83848-carrier-sense #rmii2013-04-04 9:19 AM
Hello Grant, Just wondering were you able to solve the problem?
2013-04-04 9:41 AM
Instead of playing this METOO game with a respondent here, twice, 18 months ago, why don't you clearly state your problem, with your board/circuit details, and with your schematic.
The classic issues with Ethernet connectivity tend to revolve around the clocks, the magnetics (ratio, or centre taps), wiring and component issues.2013-04-04 10:57 AM
