2019-11-19 12:51 AM
I have set the parameter "mode" in CubeMx to SD 4 bits wide bus.
But after doing so, I cannot access newer SD cards (HX) any more. Older cards (512 MB) work fine, which I assume is due to the fact that these cards do not support the 4-bit access from their side.
Are there any restriction or other settings necessary to use the 4-bit wide bus?
