2021-06-10 3:20 AM
I am using F446 board with CCA02m2.
when I just send the audio to USB output, I can record data in audacity. But if I do simple processing such as averaging data, the output is high clipped data.
I checked the data range and overflowing. there is no problem in this case.
Is there any advice here?
2021-06-10 6:48 AM
Yes. Recheck the data range and overflowing.
Instead of using real audio source, try some artifical data e.g. sawtooth.
