2026-02-04 2:19 AM - last edited on 2026-02-04 2:48 AM by Andrew Neil
2026-02-04 2:48 AM
Have you checked for examples in CubeMX and/or the STM32CubeN6 firmware package ?
https://www.st.com/en/microcontrollers-microprocessors/stm32n657x0.html#tools-software
https://www.st.com/en/microcontrollers-microprocessors/stm32n657x0.html#documentation
How to write your question to maximize your chances to find a solution
2026-02-04 3:04 AM
There is one Example NX_WEB_SERVER for the Board it uses the DHCP, but I need the Static IP Configuration, and I tried but I am Unable to bring up and open the TCP Socket, so I have Mentioned Need of guidance in order to configure the static IP and TCP Transactions
2026-02-04 3:11 AM
It would have been helpful to have explained that in the original post - rather than just leaving it blank, and giving us nothing to go on. We are not mind readers.
The better the information you provide, the more likely you are to get useful replies.
@MownishBugatha wrote:There is one Example NX_WEB_SERVER for the Board it uses the DHCP, but I need the Static IP Configuration, and I tried but I am Unable to bring up and open the TCP Socket
So this: STM32N6570-DK NX_Web_server example: Where to place .nx_data ?
And this: Break at address "0x18003a1a" with no debug information available
2026-02-04 3:21 AM
ok thanks I will modify the Questionnaire
2026-02-04 3:37 AM - edited 2026-02-04 3:40 AM
It's best not to modify a question after it's already had replies - that tends to make the existing replies no longer make sense!
Add further detail in a reply.
2026-02-04 3:45 AM
ok
