2021-07-12 5:14 AM
static void USBH_UserProcess (USBH_HandleTypeDef *phost, uint8_t id)
/* USER CODE BEGIN CALL_BACK_1 */
switch(id)
case HOST_USER_SELECT_CONFIGURATION:
break;
case HOST_USER_DISCONNECTION:
Appli_state = APPLICATION_DISCONNECT;
break;
case HOST_USER_CLASS_ACTIVE:
Appli_state = APPLICATION_READY;
break;
case HOST_USER_CONNECTION:
Appli_state = APPLICATION_START;
break;
default:
break;
/* USER CODE END CALL_BACK_1 */
2021-07-12 5:19 AM
Hi @SGasp.1 ,
Can you confirm on which platform you are working ?
I have a doubt related to "STM32 MPUs" topic you have selected ..
Thx
Olivier
2021-07-12 5:27 AM
2021-07-12 5:33 AM
Ok thanks,
I reassigned your post to STM32 MCU, STM32F7 and USB topics where I'm sure you will reach a skilled audience for your issue.
Olivier
2021-07-12 5:36 AM
Thanks Olivier
