2019-09-13 4:11 AM
Hi guys.
I have a problem with this hal function.The problem is that every time I use this function the first byte received is not what I transfer to it.For example when I send AT (ESP8266 AT command) to the module it must return AT OK,but every time(except the first time)the first byte is not A!
2019-09-14 1:41 PM
Maybe there? https://github.com/MaJerle?tab=repositories
