2025-02-13 6:23 AM
Hey there,
I recently started learning how to use Azure RTOS on STM32 with NUCLEO-h723ZG Board. While following this course
I came accross the FileX section in Session 6. At slide 31 the course wants me to delete a file and copy some other from a specific directory. As I'm using a higher version than the course I was not able to find the FileX folder in the directory mentioned.
What can I do about this problem, because I can't proceed my learning process with FileX? Is there any up-to-date-Guide that I can follow along?
2025-05-15 8:51 AM
Hello @VincentKochinke
Did you try to use the version used on the course?
