2025-07-17 12:15 AM - last edited on 2025-07-17 12:18 AM by Andrew Neil
Hi All ,
Am imported a example project in stm32cube and i tried to build am getting error as
Description Resource Path Location Type
non constant or forward reference address expression for section .ARM.extab LTDC_Paint line 90, external location: c:\st\stm32cubeide_1.6.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.9-2020-q2-update.win32_1.5.0.202011040924\tools\arm-none-eabi\bin\ld.exe:D:\stm32_projects\exp1\LTDC_Paint\STM32CubeIDE\STM32H750XBHX_FLASH.ld C/C++ Problem
can u please provide the solution.
thankyou,
regards
shiva chary
2025-07-17 12:21 AM
@shiva_chary wrote:imported a example project i
What project ? For what board ?
Please describe what you actually did.
Did you make any changes?
How to write your question to maximize your chances to find a solution
2025-07-18 1:34 AM
Hello @shiva_chary ;
Could you please referring to UM2609 section 2.1.3 Importing existing project and following the steps to open the example.
I hope this help you.
Thank you.
Kaouthar
2025-07-18 1:42 AM
@shiva_chary wrote:c:\st\stm32cubeide_1.6.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools...
Are you really using CubeIDE v1.6.0 ?
That's really old - current version is 1.19.0 !
https://community.st.com/t5/stm32cubeide-mcus/stm32cubeide-1-19-0-released/td-p/819568
2025-11-08 1:03 PM
I was also getting the same error. But when I changed the toolchain version from 10.3 -> 13.3 , it worked.
Seems like warning given in the guide is no more relevant.
Section 5: build the firmware
