2026-03-31 4:00 AM - edited 2026-03-31 4:01 AM
Hello
I have my own board with STM32G071KBT6 microcontroller. I successfully comunicate with charger by PD protocol and I receive up to 21 V (PPS). But I need above 21V. I have power bank with AVS up to 28V and USB cable with e-marker (up to 240W). How to configure the stack to receive EPR parameters? I have no TCPP IC, but I use my own protection circuit. In the trace the EPR commands isn't present. I use STM32CubeIDE 2.1.1 and STM32CubeMX 6.17.0.
Thanks a lot and best regards
2026-04-20 10:28 PM - edited 2026-04-22 10:58 PM
OK, but how to do it? My trace is below.
CAD 2 1 USBPD_CAD_STATE_DETACHED 563
CAD 4 1 USBPD_CAD_STATE_ATTACHED_WAIT 564
CAD 123 1 USBPD_CAD_STATE_ATTACHED 565
NOTIF 123 1 USBSTACK_START 566
DEBUG 123 1 ADVICE: USBPD_DPM_Notification:104 567
EVENT 123 1 EVENT_ATTACHED 568
DEBUG 123 1 ADVICE: update USBPD_DPM_UserCableDetection 569
DEBUG 123 1 ADVICE: update USBPD_DPM_SetDataInfo:2 570
DEBUG 123 1 ADVICE: update USBPD_DPM_SetDataInfo:6 571
PE 124 1 PE_SNK_STARTUP 572
PE 124 1 PE_SNK_WAIT_FOR_CAPABILITIES 573
IN 149 1 SOP PD3 s:030 H:0x71A1 (id:0, DR:DFP, PR:SRC) SRC_CAPABILITIES DATA: 2C9181282CD102002CC103002CB10400F44106003C21DCC03C21A4C1
Option: EPW DRP
[1] Fixed : 5V - 3A
[2] Fixed : 9V - 3A
[3] Fixed : 12V - 3A
[4] Fixed : 15V - 3A
[5] Fixed : 20V - 5A
[6] Programmable : [3.3V - 11V] - 3A
[7] Programmable : [3.3V - 21V] - 3A
574
OUT 149 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 575
DEBUG 149 1 Received: 28 bytes 576
DEBUG 149 1 PDO[1] = 5000 mV, 3000 mA, 15 W 577
DEBUG 150 1 PDO[2] = 9000 mV, 3000 mA, 27 W 578
DEBUG 150 1 PDO[3] = 12000 mV, 3000 mA, 36 W 579
DEBUG 150 1 PDO[4] = 15000 mV, 3000 mA, 45 W 580
DEBUG 150 1 PDO[5] = 20000 mV, 5000 mA, 100 W 581
DEBUG 150 1 APDO [6] - max voltage: 11000 mV 582
DEBUG 150 1 APDO [7] - max voltage: 21000 mV 583
PE 150 1 PE_SNK_EVALUATE_CAPABILITY 584
PE 152 1 PE_SNK_SEND_REQUEST 585
OUT 152 1 SOP PD3 REQUEST s:006 H:0x1082 (id:0, DR:UFP, PR:SNK) DATA: F4D14753
ObjectPosition:5
GiveBack:0
CapabilityMismatch:0
USBCommunicationCapable:1
NoUSBSuspend:1
UnchunkedExtendedMessagesSupported:0
MaximumOperatingCurrent:5000mA
OperatingCurrent:5000mA 586
IN 153 1 SOP s:002 H:0x0161 (id:0, DR:DFP, PR:SRC) GOODCRC 587
PE 153 1 PE_SNK_SELECT_CAPABILITY 588
IN 155 1 SOP PD3 ACCEPT s:002 H:0x03A3 (id:1, DR:DFP, PR:SRC) 589
OUT 155 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 590
NOTIF 156 1 POWER_STATE_CHANGE 591
DEBUG 156 1 ADVICE: USBPD_DPM_Notification:90 592
NOTIF 156 1 REQUEST_ACCEPTED 593
DEBUG 156 1 ADVICE: USBPD_DPM_Notification:1 594
PE 156 1 PE_SNK_TRANSITION_SNK 595
IN 453 1 SOP PD3 PS_RDY s:002 H:0x05A6 (id:2, DR:DFP, PR:SRC) 596
OUT 453 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 597
NOTIF 453 1 POWER_STATE_CHANGE 598
DEBUG 453 1 ADVICE: USBPD_DPM_Notification:90 599
NOTIF 453 1 POWER_EXPLICIT_CONTRACT 600
PE 453 1 PE_STATE_READY 601
NOTIF 453 1 STATE_SNK_READY 602
DEBUG 454 1 ADVICE: USBPD_DPM_Notification:32 603
PE 454 1 PE_STATE_SEND_EPRMODE 604
DEBUG 454 1 ADVICE: update USBPD_DPM_GetDataInfo:30 605
OUT 454 1 SOP s:006 PD3 H:0x128A (id:1, DR:UFP, PR:SNK) EPR_MODE
EPR_MODE : 01000000
Action: 01
0x01 Enter Sink only
0x02 Enter Acknowledged Source only
0x03 Enter Succeeded Source only
0x04 Enter Failed Source only
0x05 Exit Sink or Source
Data: 00
0x00 - Unknown cause
0x01 - Cable not EPR capable
0x02 - Source failed to become VCONN source
0x03 - EPR Mode Capable bit not set in RDO
0x04 - Source unable to enter EPR Mode at this time
0x05 - EPR Mode Capable bit not set in PDO
606
IN 455 1 SOP s:002 H:0x03A1 (id:1, DR:DFP, PR:SRC) GOODCRC 607
PE 455 1 PE_STATE_WAIT_EPRMODE_ACK 608
IN 456 1 SOP s:006 PD3 H:0x17AA (id:3, DR:DFP, PR:SRC) EPR_MODE
EPR_MODE : 02000000
Action: 02
Data: 00
609
OUT 456 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 610
DEBUG 457 1 ADVICE: update USBPD_DPM_SetDataInfo:23 611
NOTIF 457 1 NOTIFY_EPRMODE_ACK 612
DEBUG 457 1 ADVICE: USBPD_DPM_Notification:113 613
IN 472 1 SOP s:006 PD3 H:0x11AA (id:0, DR:DFP, PR:SRC) EPR_MODE
EPR_MODE : 03000000
Action: 03
Data: 00
614
OUT 472 1 SOP s:002 H:0x0081 (id:0, DR:UFP, PR:SNK) GOODCRC 615
PE 473 1 PE_STATE_WAIT_EPRMODE_STATUS 616
DEBUG 473 1 ADVICE: update USBPD_DPM_SetDataInfo:23 617
NOTIF 473 1 NOTIFY_EPRMODE_SUCCEEDED 618
DEBUG 473 1 ADVICE: USBPD_DPM_Notification:114 619
PE 473 1 PE_SNK_WAIT_FOR_CAPABILITIES 620
IN 475 1 SOP s:030 PD3 H:0xF3B1 (id:1, DR:DFP, PR:SRC) EXT_EPR_SOURCE_CAPA EXT:CNu0Ch1CReq0DSiz32 [ CHUNK BEGIN ] DATA: 2C9181282CD102002CC103002CB10400F44106003C21DCC03C21 621
OUT 475 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC 622
OUT 476 1 SOP s:006 PD3 H:0x9491 (id:2, DR:UFP, PR:SNK) EXT_EPR_SOURCE_CAPA EXT:CNu1Ch1CReq1DSiz0 DATA: 0000 623
IN 478 1 SOP s:002 H:0x05A1 (id:2, DR:DFP, PR:SRC) GOODCRC 624
IN 479 1 SOP s:014 PD3 H:0xB5B1 (id:2, DR:DFP, PR:SRC) EXT_EPR_SOURCE_CAPA EXT:CNu1Ch1CReq0DSiz36 [ CHUNK END ]
EPR SOURCE CAPA
[1] Fixed : 5V - 3A
[2] Fixed : 9V - 3A
[6] EPR : [11V - 3.3V] - 60W
[7] EPR : [21V - 3.3V] - 60W
[8] Fixed : 28V - 5A
[9] EPR : [28V - 15V] - 140W
DATA: A4C1F4C188008C9630D2 625
OUT 479 1 SOP s:002 H:0x0481 (id:2, DR:UFP, PR:SNK) GOODCRC 626
DEBUG 480 1 Received: 28 bytes 627
DEBUG 480 1 PDO[1] = 5000 mV, 3000 mA, 15 W 628
DEBUG 480 1 PDO[2] = 9000 mV, 3000 mA, 27 W 629
DEBUG 480 1 PDO[3] = 12000 mV, 3000 mA, 36 W 630
DEBUG 480 1 PDO[4] = 15000 mV, 3000 mA, 45 W 631
DEBUG 480 1 PDO[5] = 20000 mV, 5000 mA, 100 W 632
DEBUG 480 1 APDO [6] - max voltage: 11000 mV 633
DEBUG 480 1 APDO [7] - max voltage: 21000 mV 634
DEBUG 481 1 EPR - received: 4 bytes 635
DEBUG 481 1 Called: 1 x 636
DEBUG 481 1 0x0088C1F4 637
DEBUG 481 1 EPR - max voltage: 6800 mV 638
PE 481 1 PE_SNK_EVALUATE_CAPABILITY 639
PE 482 1 PE_SNK_SEND_REQUEST 640
DEBUG 482 1 ADVICE: update USBPD_DPM_GetDataInfo:29 641
OUT 482 1 SOP PD3 EPR_REQUEST s:010 H:0x2689 (id:3, DR:UFP, PR:SNK) DATA: F4D1475300000000
ObjectPosition:5
GiveBack:0
NoUSBSuspend:1
OperatingCurrent:5000mA 642
IN 484 1 SOP s:002 H:0x07A1 (id:3, DR:DFP, PR:SRC) GOODCRC 643
PE 484 1 PE_SNK_SELECT_CAPABILITY 644
IN 485 1 SOP PD3 ACCEPT s:002 H:0x07A3 (id:3, DR:DFP, PR:SRC) 645
OUT 485 1 SOP s:002 H:0x0681 (id:3, DR:UFP, PR:SNK) GOODCRC 646
NOTIF 486 1 POWER_STATE_CHANGE 647
DEBUG 486 1 ADVICE: USBPD_DPM_Notification:90 648
NOTIF 486 1 REQUEST_ACCEPTED 649
DEBUG 486 1 ADVICE: USBPD_DPM_Notification:1 650
PE 486 1 PE_SNK_TRANSITION_SNK 651
IN 781 1 SOP PD3 PS_RDY s:002 H:0x09A6 (id:4, DR:DFP, PR:SRC) 652
OUT 781 1 SOP s:002 H:0x0881 (id:4, DR:UFP, PR:SNK) GOODCRC 653
NOTIF 781 1 POWER_STATE_CHANGE 654
DEBUG 781 1 ADVICE: USBPD_DPM_Notification:90 655
NOTIF 781 1 POWER_EXPLICIT_CONTRACT 656
PE 781 1 PE_STATE_READY 657
NOTIF 781 1 STATE_SNK_READY 658
DEBUG 781 1 ADVICE: USBPD_DPM_Notification:32 659
PE 781 1 PE_STATE_SEND_EPRMODE 660
DEBUG 781 1 ADVICE: update USBPD_DPM_GetDataInfo:30 661
OUT 781 1 SOP s:006 PD3 H:0x188A (id:4, DR:UFP, PR:SNK) EPR_MODE
EPR_MODE : 01000000
Action: 01
Data: 00
662
IN 783 1 SOP s:002 H:0x09A1 (id:4, DR:DFP, PR:SRC) GOODCRC 663
PE 783 1 PE_STATE_WAIT_EPRMODE_ACK 664
IN 1747 1 HRST 665
NOTIF 1747 1 HARDRESET_RX 666
DEBUG 1747 1 ADVICE: USBPD_DPM_Notification:30 667
PE 1747 1 PE_HARD_RESET_RECEIVED 668
PE 1747 1 PE_SNK_HARD_RESET_WAIT_VSAFE_0V 669
GUI 0 BOARD RESET BY USER 670
CAD 4 1 USBPD_CAD_STATE_ATTACHED_WAIT 671
OK, I have checked it. The message is chunked - below:
391 IN 1042 1 SOP s:030 PD3 H:0xF3B1 (id:1, DR:DFP, PR:SRC) EXT_EPR_SOURCE_CAPA EXT:CNu0Ch1CReq0DSiz32 [ CHUNK BEGIN ] DATA: 2C9181282CD102002CC103002CB10400F44106003C21DCC03C21
392 OUT 1042 1 SOP s:002 H:0x0281 (id:1, DR:UFP, PR:SNK) GOODCRC
393 OUT 1043 1 SOP s:006 PD3 H:0x9491 (id:2, DR:UFP, PR:SNK) EXT_EPR_SOURCE_CAPA EXT:CNu1Ch1CReq1DSiz0 DATA: 0000
394 IN 1044 1 SOP s:002 H:0x05A1 (id:2, DR:DFP, PR:SRC) GOODCRC
395 IN 1046 1 SOP s:014 PD3 H:0xB5B1 (id:2, DR:DFP, PR:SRC) EXT_EPR_SOURCE_CAPA EXT:CNu1Ch1CReq0DSiz36 [ CHUNK END ] / EPR SOURCE CAPA / [1] Fixed : 5V - 3A / [2] Fixed : 9V - 3A / [3] Fixed : 12V - 3A / [4] Fixed : 15V - 3A / [5] Fixed : 20V - 5A / [6] EPR : [11V - 3.3V] - 60W / [7] EPR : [21V - 3.3V] - 60W / [8] Fixed : 28V - 5A / [9] EPR : [28V - 15V] - 140W / DATA: A4C1F4C188008C9630D2
During the test I have discovered, that "EPR" variable in my code (below) takes on the different value depending on the "x" variable. I.e. x=1 -> EPR=0xD230968C, so Max_voltage_100mV*100=28000. Once I have 4 bytes (Size = 4). How to recognize all PDO and APDO values?
case USBPD_CORE_DATATYPE_RCV_SRC_PDO_EPR:
uint32_t x=1;
uint32_t EPR_1=0;
uint32_t EPR_2=0;
uint32_t EPR_3=0;
uint32_t EPR_4=0;
uint32_t EPR=0;
DPM_USER_DEBUG_TRACE(PortNum, "EPR - received: %lu bytes", Size);
EPR_1=0;
EPR_2=0;
EPR_3=0;
EPR_4=0;
EPR=0;
EPR_1=(uint32_t)Ptr[x*4U+0U]<<0;
EPR_2=(uint32_t)Ptr[x*4U+1U]<<8;
EPR_3=(uint32_t)Ptr[x*4U+2U]<<16;
EPR_4=(uint32_t)Ptr[x*4U+3U]<<24;
EPR=EPR_1|EPR_2|EPR_3|EPR_4;
DPM_USER_DEBUG_TRACE(PortNum, "0x%08lX", EPR);
uint32_t Max_Voltage_100mV=(EPR>>17);
Max_Voltage_100mV = Max_Voltage_100mV&0b00000000000000000000000111111111;
DPM_USER_DEBUG_TRACE(PortNum, "EPR - max voltage: %lu mV", (Max_Voltage_100mV*100));
Best regards
Jaroslaw
2026-04-23 7:53 AM
OK @Jaroslaw_T since USBPD_CORE_DATATYPE_RCV_SRC_PDO_EPR only exposes the first 4 bytes of the reassembled extended payload and source is sending properly chunked messages, the limitation appears to be in the middleware. Could you confirm reproducing using latest version of stm32-mw-usbpd-core v5.4? If possible to reproduce on one of our reference boards to confirm the issue is not linked to your hardware setup.
2026-04-23 10:28 PM - edited 2026-04-23 11:12 PM
Yes, @FBL I have using the last USPPD core (v5.4) from GITHUB.
I have modified my code and I found:
for "x" = 0 - I have information about EPR PDO,
for "x" = 1- I have information about EPR APDO
But how to recognize the max number of "x"?
My code after changing:
uint32_t x=0;
uint32_t EPR_1=0;
uint32_t EPR_2=0;
uint32_t EPR_3=0;
uint32_t EPR_4=0;
uint32_t EPR=0;
EPR_1=0;
EPR_2=0;
EPR_3=0;
EPR_4=0;
EPR=0;
if((EPR&0b11000000000000000000000000000000UL)!=0b11000000000000000000000000000000UL)
EPR_Voltage=(EPR>>10);
EPR_Voltage=EPR_Voltage&0b00000000000000000000001111111111;
EPR_Voltage=EPR_Voltage*50;
EPR_Current=EPR&0b00000000000000000000001111111111;
EPR_Current=EPR_Current*10;
DPM_USER_DEBUG_TRACE(PortNum, "EPR = %lu mV, %lu mA", EPR_Voltage, EPR_Current);
if((EPR&0b11000000000000000000000000000000UL)==0b11000000000000000000000000000000UL)
break;
In the next step I have used global variable Number_Of_EPR_PDO:
main.c
uint8_t Number_Of_EPR_PDO = 0;
main.h
extern uint8_t Number_Of_EPR_PDO;
And in usbpd_dpm_user.c I have information about 1 PDO (Number_Of_EPR_PDO = 1)
Number_Of_EPR_PDO++;
uint8_t x=0;
uint32_t EPR_1=0;
uint32_t EPR_2=0;
uint32_t EPR_3=0;
uint32_t EPR_4=0;
uint32_t EPR=0;
DPM_USER_DEBUG_TRACE(PortNum, "EPR - received: %lu bytes, %d PDOs", Size, Number_Of_EPR_PDO);1507 DEBUG 1050 1 EPR - received: 4 bytes, 1 PDOs
Best regards
Jaroslaw
2026-04-27 11:16 PM
Hello community
I have done another test.
In trace I have 9 positions - last one is AVS 15 - 28V, 140W:
2707 IN 1048 1 SOP s:014 PD3 H:0xB5B1 (id:2, DR:DFP, PR:SRC) EXT_EPR_SOURCE_CAPA EXT:CNu1Ch1CReq0DSiz36 [ CHUNK END ] / EPR SOURCE CAPA / [1] Fixed : 5V - 3A / [2] Fixed : 9V - 3A / [3] Fixed : 12V - 3A / [4] Fixed : 15V - 3A / [5] Fixed : 20V - 5A / [6] EPR : [11V - 3.3V] - 60W / [7] EPR : [21V - 3.3V] - 60W / [8] Fixed : 28V - 5A / [9] EPR : [28V - 15V] - 140W / DATA: A4C1F4C188008C9630D2So I have tried to choose 9 position:
DPM_USER_DEBUG_TRACE(PortNum, "AVS mode");
rdo.d32=0;
rdo.AVSRDO.EPR_Capable=1U;
rdo.AVSRDO.ObjectPosition=9;
rdo.AVSRDO.OutputVoltageIn25mV=960;
rdo.AVSRDO.OperatingCurrentIn50mAunits=60U; //3A
rdo.AVSRDO.NoUSBSuspend=USBPD_ENABLE;
rdo.AVSRDO.USBCommunicationsCapable=USBPD_ENABLE;
rdo.AVSRDO.CapabilityMismatch=0;
*PtrPowerObjectType=USBPD_CORE_PDO_TYPE_AVSPDO;
*PtrRequestData=rdo.d32;
But the stack sent strange values:
2720 PE 1050 1 PE_SNK_EVALUATE_CAPABILITY
2721 DEBUG 1052 1 AVS mode
2722 PE 1052 1 PE_SNK_SEND_REQUEST
2723 DEBUG 1052 1 ADVICE: update USBPD_DPM_GetDataInfo:29
2724 OUT 1052 1 SOP PD3 EPR_REQUEST s:010 H:0x2689 (id:3, DR:UFP, PR:SNK) DATA: 3C80479300000000 / ObjectPosition:1 / GiveBack:0 / CapabilityMismatch:0 / USBCommunicationCapable:1 / NoUSBSuspend:1 / UnchunkedExtendedMessagesSupported:0 / MaximumOperatingCurrent:600mA / OperatingCurrent:4800mA
2725 IN 1054 1 SOP s:002 H:0x07A1 (id:3, DR:DFP, PR:SRC) GOODCRC
2726 PE 1054 1 PE_SNK_SELECT_CAPABILITY
2727 IN 1055 1 HRST
2728 NOTIF 1055 1 HARDRESET_RX
Why?
Best regards
Jaroslaw
2026-05-06 12:00 AM
Hello :)
Any ideas about my problems? Can someone help me?
