Set Nucleo-l476RG as Audio Device
Hello everyone, I am working on a project in wich I want to use a nucleo-l476RG as a MIDI device. I saw on midi official website that the USB Audioclass was compliant with MIDI application (https://www.midi.org/midi-articles/basic-of-usb). However wh...
Mc3 by Associate II
  • 3541 Views
Resolved! FSMC access thread safe?
Supposed I am using external memory via an 16 bit address / 8 bit data bus with FSMC (STM32F714). An RTOS is running.Is access to this memory atomic (in the sense of thread safety) when I read/write 32 bit wide data? The consideration is, for instanc...
Ingmar by Associate II
  • 1572 Views
Timeout values in STM32G4 bootloader ?
Hi all,Bootloader selection for STM32G47xxxx described in AN2606 shows the different steps followed by the bootloader.Where can I find the delays available between steps ?For example, how long the booloader waits to receive the 0x7F value on USARTx ?...
YJ by Associate II
  • 1649 Views
Resolved! USB HID performance optimization
I'm planning to use a cheap STM32 board (either with a F103 or F401/11) as a joystick/rotary encoder controller for arcade games. I already have a working proof of concept using the old STM32duino cores (not HAL based), but I prefer to use the HAL en...
fbar by Senior
  • 4064 Views
uart no work with freeRtos
Welcome everyoneI used Free ROS with two tasks, the first task was to blink the led and the second task was to receive from uart and then to resend the received message. The two tasks have the same priorityThe led flash works fine but the uart only r...
xmart by Associate II
  • 878 Views
