Move bulk of USB MSC ISR to user thread.
CubeMX USB MSC creates a large protocol stack to allow USB MSC to get to MMC memory device. This all runs directly from the ISR. We want as much of this to run in a user thread instead.My concerns are how will the low-level USB work with this kind of...
Interfacing TDM bus with STM32F4
Hello We need to interface TDM bus with USB from i7 based embedded PC. I saw "STM32 USB Device Audio Streaming software expansion for STM32Cube" and I am consider using it. Let me put here our requirement, possibly someone can comment if what we need...
dpn by Associate II
  • 1092 Views
Resolved! (Solved) Can't transfer specific byte sequence over VCP
So far I have been using VCP in my project for about six months with no problems. But today I found it was not able to send a specific 'packet' of bytes.Here is the SWV printf output from STM32CubeIDE:Sending 10 bytes 255 254 5 0 19 0 0 0 24 106Note ...
iforce2d by Associate III
  • 2787 Views
Resolved! STM32F042K6 USB HID Library Size Problem
Hi,I have created a CubeMx project for STM32F042K6. I am using following components:USBTSCIWDGGPIOTOUCHSENSINGUSB_DEVICEI just defined the pins and tried to compile but compiler says FLASH overflows around 2.5KI didn't even write one line of code. Th...
