HS USB Device Audio-In on STM32F769 Discovery issues. DataIn event is not fired every time, the setup command to turn the microphone on is received .
For a little background, i have modified the project to take audio data from a static file to eliminate any issues with interrupts from the mems microphones may have been causing though the result is the same. I have also added print statements to t...
gvigelet by Associate II
  • 1986 Views
DEBUGGING ISSUE WITH USB-C
Hello community,I'm experiencing difficulty when debugging my software.I'm running Mac OS Catalina with a L433 Nucleo, plugged into my USB-C to USB-A converter.I wrote a very basic "echo" program to take my USART input and echo it back to my Mac.I ke...
STayl.3 by Associate II
  • 2310 Views
STM32 FreeRTOS
I am using STM32F072RB.I have enable the FreeRTOS CMSIS1.I have created two tasks which uses the same UART for transmitting data.I want to use the semaphore concept to use this shared resource between two task.The task as belows:TASK 1 High priorit...
Bs.1 by Associate II
  • 1416 Views
Resolved! problem with USB and timer
Hello,I need your help to recognize my issue correctly, please help me,background:I am having trouble using the stm32l053RB NUCLEO development board for USB protocol parsing.issue:When​ using timer to generate PWM, once the USB receive data is confi...
Jsong by Associate II
  • 6895 Views
  • 12 replies
TouchGfx with QSPI + Audio
Hi,I am working on a project using STM32F7. So far I have touchgfx working with external QSPI for storing image resources. Everything is working good and expected so far.Now I would like to add audio functionality. The aim is to play WAV files when a...
VBUS not connected
I am trying to make USB work on a custom board. On our board the VBUS and ID lines from the USB-B connector is left floating, Because we always want to be in device modeSo to compensate for this I am using B-peripheral session valid override. This in...
LHoug.1 by Associate II
  • 986 Views
Resolved! STM32G4 + USB PD + Switching power profiles
I am studying USB PD now with the demo board B-G474E-DPOW1.I try to program the consumer and need help with switching profiles. When the cable is connected, the charger displays a list of available profiles. I can't figure out how to choose the right...
ADoro.2 by Associate III
  • 1941 Views
