DMA ethernet descriptor OWN bit issue
Im using stm32f207 HAL library, LwIP stack with RAW api, no RTOS for an UDP server implementation. Server is receiving frames by polling way because of client nature demands. Client is constantly asking server for reading mcu inputs and asking for wr...
genisuvi by Associate III
  • 1713 Views
Problem with FreeRTOS ISR Task Notification
I am using Nucleo F411RE dev borad. When I using the FreeRTOS, I found that the xTaskNotifyFromISR always stuck.my handler function as below and I can enter it normally.the program stop at -------------------------------------------------------------...
smok.1 by Associate
  • 3488 Views
Ethernet DHCP and static IP mode
Hi allCurrently, I am working on a project in which I have to design an application in such a way that it should support DHCP and static IP mode based on user choice. And this would be in FREERTOS. Users can back and forth between static and DHCP mod...
spate.2 by Associate III
  • 4431 Views
