2023-06-02 1:59 AM
2023-06-02 2:13 AM
Hi @JSanc.7 ,
STM32CubeProjectsList.html provided in the STM32Cube Package lists all project supported per board.
Then for each example you have an associated readme.txt file explaining purpose and how to.
Is that match your request ?
Olivier
2023-06-02 3:58 AM
For example, for 'F4, here.
Github won't serve it as html, so you have to download it as raw, and then open locally.
2023-06-02 4:58 AM
Or here rendered.
2023-06-02 5:03 AM
Thanks, Pavel. One learns something new every day.
Jan
2023-06-02 5:06 AM
Hi Olivier,
fancy to write an Article here, perhaps giving links to existing Cubes' apps lists, using the trick Pavel gave above?
Thanks,
@Community member
2023-06-02 5:19 AM
Indeed @Community member , the tips given by @Pavel A. can likely be well used to ease access of such information.
Idea highlighted/escalated inside ST.
Thank you both.
Olivier
