simple uart dma transmit for logs ?
Hello everyone,I'm working on stm32f103.I try to use HAL_uart_transmit_DMA, in a circular buffer for simple logs.I created a circular buffer, on which I can write my strings.the issue is... my circular DMA write it as as loop instead as finishing at ...
Hvan .4 by Associate II
  • 3051 Views
Resolved! SDIO configuration stm32f429
Hello dear engineers,I have gotten stuck in running SDIO on stm32f429igt6.No matter how hard I have tried, I wasn't able to successfully use FATFS with SDIO and stm32f429igt6. My code is attached. the f_mount function with immediate force on mounting...
USB PD: Sending Battery_Status Data Message
Hi ST USB PD community. I'm using https://github.com/STMicroelectronics/x-cube-tcpp but can't seem to find the right callbacks to respond to our port-partner when they send a Get_Battery_Status command.I need the ST MCU to respond with the Battery_St...
DDesr.1 by Associate II
  • 4533 Views
