SAI witH CODEC SGTL5000
Hello,I would like to know how to recover acquisition data ​​and save the data to an SD card. I have this configurationI can compile and communicate with I2C to configure the SGTL5000 CODEC, I enabled DMA too. No errors for this moments.Thank you for...
DYann.1 by Senior II
  • 1972 Views
X-Cube-Cellular low power
Hello all,I am working with the LBAD0ZZ1SE module, also used on the B-L462E-CELL1.I successfully adapted the "Nx_TCP_Echo_Client" Sample from X-Cube_cellular 7.1.0 to fit my needs but right now am stuck at the final step, which is the low power mode....
NHuhs by Associate
  • 1170 Views
Multiple ADC Channels (using registers)
Hello all, I am currently working on a project in which I need to sample 5 ADC channels every 50 ms. As of now, I am trying to use TIM2's TRGO (interrupt triggered every 50 ms) to trigger the conversion of a regular sequence of 5 ADC channels (PA0 - ...
caden013 by Associate II
  • 2291 Views
P-NUCLEO-LRWAN2
I have the P-NUCLEO-LRWAN2 package. The Gateway (NUCLEO-F746ZG with the RisingHF ARDUINO® expansion board (LRWAN_GS_HF1) has a firmware VERSION: 2.1.7, Nov 6 2018. I was wondering if there is an update to the firmware and what the current version of ...
Grey by Associate
  • 1752 Views
