Adapt Openbootloader to other MCUs
I'd like to adapt Openbootloader to the H523/H533 chip.In STM32CubeIDE, there are example applications for several microcontrollers/development boards. I noticed there was an example for the STM32H5731-DK, but I'd like to use it on the H523/H533 chip...
X-CUBE-EEPROM page erase on startup
Hi,I am trying to us X-CUBE-EEPROM to store a few variables.I would like to perform memory cleanup on startup. It is the only time I can reliably do that, since the operation is blocking read of instructions from flash.Is there any way I can tell the...
FileX on NUCLEO-H723ZG
Hey there, I recently started learning how to use Azure RTOS on STM32 with NUCLEO-h723ZG Board. While following this courseDeveloping with Azure RTOS on STM32 Series Microcontrollershttps://academy.st.com/s/learning-plan-detail-standard?ltui__urlReco...
"HAL_FDCAN_GetRxMessage" function on STM32H5
Good morning,I have a doubt regarding the behavior of the "HAL_FDCAN_GetRxMessage" routine of the HAL for the FDCAN peripheral.I am using an STM32H563VGT6 microcontroller.From what I can observe by inspecting the code, it seems that when overwrite is...
DAUSILI by Associate III
  • 1471 Views
Eclipse Threadx
I have a project (STM32H7) using Eclipse ThreadX 6.4.0. I would like to use the safety certified version of ThreadX (6.4.2). How would I go about this transition? Is there an application note covering this subject? Thanks, Gil
Gil1 by Associate III
  • 1445 Views
