Arbitrary waveform by timer using DMA
Hello,I want to generate an arbitrary waveform by a timer using DMA. The waveform is using different pulse widths and also varying periods in multiples of 25µs.By reading AN4776 and HAL documentation I figured out it should be possible with HAL_TIM_D...
RAltm by Senior
  • 841 Views
  • 14 replies
STM32F4 + DP83848: Ethernet not working
I am a beginner in electronics. I recently designed a board using the STM32F407VGT6 and DP83848, but after assembly and testing, I encountered a problem.  The board can be programmed and it runs, but the Ethernet section does not work properly.  It d...
