I3C issues with DMA, no hdmacr handle
Dear ST Community,I'm trying to integrate I3C with DMA capability in my project (NUCLEO-H563ZI). Currently, I can run SPI/UART with DMA enabled, but I3C does not want to join the club (it works with IT, though).After I configure DMA for I3C in the ST...
DanLumi_0-1750464029325.png DanLumi_1-1750464044907.png DanLumi_2-1750464079003.png DanLumi_3-1750464091982.png
DanLumi by Associate II
  • 978 Views
Update MPER register with every HRTIM period
I am also failing in reproducing the DMA example from https://wiki.st.com/stm32mcu/wiki/Getting_started_with_HRTIM#To_go_further_about_DMA_burst. HAL_HRTIM_BurstDMAConfig() is mentioned in the text, but not present in the code example. Did you miss t...
Odiug by Associate II
  • 680 Views
Need Disk i/o.c for mmc flash for FATFS
Hi all,I am using the MTFC8GAMALNA-AAT 8GB flash memory via SDMMC1, operating in MMC 4-bit wide bus mode, along with FATFS (M7). I now require the diskio.c file. Kindly provide it, or if you have any related example code, please share that as well. P...
Resolved! FreeRTOS Hard Fault issue
NUCLEO F411RE I'm checking to see if I've got FreeRTOS integrated properly. So I've set up 2 tasks each with their own counter. In debug I was expecting to see the counter for Task1 to count up whilst Task2 never gets updated.When I step through the ...
Resolved! USBX Device MSC in Standalone mode
I'm trying to get USBX Device MSC to work in Standalone mode (without RTOS).  I loosely followed @B.Montanari 's example in https://community.st.com/t5/stm32-mcus/how-to-implement-usbx-in-standalone-mode/ta-p/614435, and also referred to a CubeMX exa...
PRuss by Associate II
  • 6521 Views
  • 7 kudos
