printf with HAL_UART_Transmit_IT?
Posted on November 09, 2016 at 10:34 I am new to the hal libraries (but not stm32 devices) and struggle to see howHAL_UART_Transmit_IT is expected to be used for something simple like printf over uart. Take a blocking example: void...
toby2 by Senior
  • 15631 Views
  • 30 replies
stm32cube plugin for qtcreator
Posted on May 03, 2014 at 13:19Hello, I think I have a problem similar to the one described in the post ''STM32CubeMX as Eclipse plugin on Linux 64 machine''. As I'm really reluctant to use eclipse, I would like to know if a plugin for Qtcreator is ...
Resolved! FreeRTOS and SDIO setting ?
Posted on March 24, 2017 at 14:38Everyone,I tried to run SDIO with RTOS, but never got luck,Any ideas why ?If I disabled RTOS, SDIO can run properly but if I enabled it, SDIO is stopped running..Thanks#freertos #sdio
Debug problems with STM32F030
Posted on March 26, 2017 at 21:35 Hello. I'm trying to debug code on STM32F SWD debug wire is enabled. I can get into debug mode! The problem is that the code blocks whenever a HAL_Delay() occurs. I think the problem is related to systick...
USART bootloader protocol firmware
Posted on March 26, 2017 at 10:33Good day!There is 'http://www.st.com/content/ccc/resource/technical/document/application_note/51/5f/03/1e/bd/9b/45/be/CD00264342.pdf/files/CD00264342.pdf/jcr:content/translations/en.CD00264342.pdf'. And as I understa...
A qustion about osThreadId?
Posted on March 28, 2017 at 05:34 Everyone, I have a puzzle in my mind, how can I change the Id into a specific one for a different task ? on freetos.c : osThreadId defaultTaskHandle; osThreadId secondTaskHandle;�?�? on cmisis_os.h : ...
FreeRTOS, Systick and Timer2 ?
Posted on March 26, 2017 at 00:01Everybody,I have a question in regard, FreeRTOS, Systick and Timer2 ?How can I use Timer2 as Systick in FreeRTOS ?And what is the relation between SDIO preemption priority global interrupt with FreeRTOS ?Thanks and h...
