LIN constantly receiving and sending?
Hello all,I am on the STM23 H750 discovery dev. kit working either in Keil or CubeZone IDE-just started, anyway, so far so good, and according to the logic analyser the LIN works, at least the checksum is right :) So far I am sending the frame once t...
Resolved! FreeRTOS Tickless mode
Hi all,I ran into an issue regarding FreeRTOS tickless idle mode. I wanted to share my findings and solution in case others encounter the same problem and also to ask if that's intended structure (so I am missing something) or if its not generated pr...
Martí by Associate II
  • 1108 Views
Resolved! How a GPIO pin binds to a PWM channel
Hi Sir,I tried to refer to the PWM example:~\stm32cubeh7-v1-12-0\STM32Cube_FW_H7_V1.12.0\Projects\STM32H743I-EVAL\Examples\TIM\TIM_PWMOutput I see the four GPIO pins are initialized: And I see the four PWM channels are setup: But I can't find the cod...
Jimmy_Ma by Associate II
  • 720 Views
  • 4 kudos
STM32H7 MDMA for UART DMA
Hello,I would like to transfer 3 linked list blocks over UART DMA. When I started HAL_MDMA_START_IT, it transmits only 16 bytes. How can I send big files back to back? Configurations are as follows:MCU : STM32H7 seriesFirmware : Last release
farukisiker_5-1757421149337.png farukisiker_1-1757421028330.png farukisiker_2-1757421036690.png farukisiker_3-1757421050768.png
