Free rtos build error when using queues using stm32cube IDE. configUSE_QUEUE_SETS set to 1 not found in FreeRTOSCOnfig.h
Hi, I am trying to implement Queues for my application having three tasks. Two tasks sending messages and third task will receive the messages from task 1 and task 2.But when I build I am getting this errors.20:52:21 **** Incremental Build of config...
Kumar B by Associate II
  • 1543 Views
How to get my STM32F407VG to talk with my PC?
I've tried many programs and configurations to get my board to printf text to my PC while running tera term to receive the text. But everything I've tried has failed. In the following program, pushing the blue button is supposed to turn on the green ...
I'm trying to run CM4 in debugger mode in STM32H757I-EVAL board for "HSEM_ResourceSharing" example code. But, debugger mode exits immediately with warning message. How to fix this?
I'm trying to run CM4 in debugger mode in STM32H757I-EVAL board for "HSEM_ResourceSharing" example code. But, debugger mode exits immediately with warning message "The stack pointer for stack 'CSTACK' (currently 0xA05F0001) is outside the stack range...
S.Kamath by Associate III
  • 1345 Views
STM32H7 HAL library release notes are 0.1 off?
The latest section in the Release notes html in version 1.7 is numbered 1.8 and has release date 14 Feb. 2020. Version 1.7 there has release date 06 december 2019. Looks like these versions are 0.1 up. The latest release is 1.7 and it should have da...
Pavel A. by Super User
  • 1383 Views
