IAP application with STM32CubeIDE/ STLink
Hi everyone,I'm following the LWIP_IAP application in STM32756G_EVAL 's Repository. The bootloader work fine, but I don't know how to config the application firmware to boot from a specify address flash.Is this the right way to config flash memory o...
AWS IoT Core Connection
Hi, I'm looking to connect a STM32H7 board to iot core, simple stuff: publish and subscribe to topics.I found x-cube-aws but i don't know how it works (I read the getting started guide but no success).In the aws documentation for freertos i didn't fo...
MGera.1 by Associate
  • 791 Views
i am using stm32f103xE MCU. i am using FATFS with SDIO. it's opening the file, but when i am writing the data to the file it's giving the FR_INVALID_OBJECT Error.
char data[] = "Testing File";if(f_mount(&fs, SD_Path, 0) == FR_OK) {  if(f_open(&myFile, "Test_File.txt", FA_WRITE | FA_CREATE_ALWAYS) == FR_OK)  {    if(f_write(&myFile, data, sizeof(data), &myBytes) == FR_OK)    {     f_close(&myFile);    }   f_clo...
SPARV.1 by Associate
  • 1151 Views
