Bug in GPDMA with 2D addressing (I think)
I believe there's a bug in the stm32h7rsxx_hal_dma code for dealing with repeated blocks in interrupt mode. This bug probably exists in other STM32H7 devices as well.With a typical repeating transfer, in *NON* interrupt mode, the DMA transfer complet...
FA1234 by Associate III
  • 2483 Views
Sequential I2C problems on STM32F030
I'm re-using a sequential I2C library that worked on a couple other ST devices with different I2C devices, but it doesn't work on a STM32F030.They are functions for I2C register operations, where we always start with a write with the register address...
Bug in fx_stm32_sd_driver.c
I think I have found a bug in the mentioned file (in my case the file comes from x-cube_azrtos-h7, but the problem seems to be present in other versions to).In the function fx_stm32_sd_driver() there is a check that the passed Databuffer (media_ptr→f...
MHoll.2 by Senior III
  • 518 Views
