2019-05-13 12:18 PM
Hello all,
I recently bought the B-L475E-IOT running the following example. en.stm32cubel4\STM32Cube_FW_L4_V1.13.0\Projects\B-L475E-IOT01A\Applications\WiFi\WiFi_HTTP_Server, which concerns an http server. By testing it, I notice that the third time I want to turn the led on through the browser, then the page does not load.
I notice that in function "ES_WIFI_Status_t ES_WIFI_StartServerSingleConn(ES_WIFIObject_t *Obj, ES_WIFI_Conn_t *conn)", when the browser page does not load, the wifi module does not send the word "Accepted".
do
sprintf((char*)Obj->CmdData,"MR\r");
ret = AT_ExecuteCommand(Obj, Obj->CmdData, Obj->CmdData);
if(ret == ES_WIFI_STATUS_OK)
if((strstr((char *)Obj->CmdData, "[SOMA]")) && (strstr((char *)Obj->CmdData, "[EOMA]")))
if(strstr((char *)Obj->CmdData, "Accepted"))
ptr = strtok((char *)Obj->CmdData + 2, " ");
ptr = strtok(NULL, " ");
ptr = strtok(NULL, ":");
ParseIP((char *)ptr, conn->RemoteIP);
ret = ES_WIFI_STATUS_OK;
break;
Is there a possibility of damaging the wifi module? Or, do you have any idea what might be wrong?
Τhanks in advance!
2019-06-12 10:52 AM
I have the same issue
2020-10-03 11:47 PM
the same happens to me
manage to correct the problem ??
