2023-05-25 12:58 PM
See this link:
https://learn.microsoft.com/en-us/azure/rtos/threadx-modules/chapter1
Would like to explore the options of using this method to partition code.
2023-05-30 3:04 PM
Yes, this is what prompted my look at if CubeMx supports the feature selection. Sadly, ST has not worked on this. However there is an example in git called B-U585I-IOT02A_MODULE_MANAGER_THREADX.
The MOOC only makes mention of ModuleX but does not go into any detail.
2023-05-25 3:17 PM
The first thing I notice is that the Software Packs>Select Components in CubeMX does not include Modules in the ThreadX section. However, the needed txm_module.h is present in ...\STM32Cube\Repository\Packs\STMicroelectronics\X-CUBE-AZRTOS-H7\3.1.0\Middlewares\ST\threadx\common_modules along with the other files needed.
I guess CubeMX does not currently support adding Module support to the project.
2023-05-30 1:17 AM
Hello @Community member,
Check this wiki about ThreadX
Introduction to THREADX - stm32mcu
I will let my colleague check if CubeMX is supporting middleware.
2023-05-30 1:42 AM
I advise you, to get inspired form the steps described in this workshop: MOOC - Azure RTOS step by step workshop
Thx
Ghofrane
2023-05-30 3:04 PM
