2021-12-02 11:11 PM
Is there a similar guide to this: How to create project for STM32H7 with Ethernet and LwIP stack working, but instead using Azure RTOS?
I know there are code examples in CubeMX but I would prefer a simple step-by-step guide including the CubeMX configurations
2021-12-07 12:31 AM
Thank you very much for sharing this good proposal, I will check with AzureRTOS authors and make sure it is in our backlog!
Thanks,
Laura
2021-12-06 9:11 AM
Hi @Lars Sörqvist ,
There is the article How to create a Thread using AzureRTOS and STM32CubeIDE?.
Is this what you are looking for? If yes, you can mark my answer as best answer.
-Amel
2021-12-06 10:09 PM
Hi Amel,
Thanks, that is a good example of using threading with Azure ThreadX, and I have been using it.
However, I was hoping to find something about setting up a web server using Azure NetXDuo. A sort of step-by-step guide like the link I provided above.
2021-12-07 12:19 AM
That is a good proposal for a new article @Lars Sörqvist .
@Laura C. , do we have such article on the pipe?
Thanks,
-Amel
2021-12-07 12:31 AM
Thanks,
Laura
