2024-11-08 11:47 AM - last edited on 2024-11-08 11:54 AM by mƎALLEm
I am having a strange ADC problem on my STM32L431 device. I am sampling 6 channels without DMA using polling method with the following code:
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
ADC_Select_CH0();
HAL_ADC_Start(&hadc1);
HAL_ADC_PollForConversion(&hadc1, HAL_MAX_DELAY);
adc_values[0] = HAL_ADC_GetValue(&hadc1);
HAL_ADC_Stop(&hadc1);
HAL_Delay(100);
ADC_Select_CH1();
adc_values[1] = HAL_ADC_GetValue(&hadc1);
HAL_Delay(100);
ADC_Select_CH2();
adc_values[2] = HAL_ADC_GetValue(&hadc1);
HAL_Delay(100);
ADC_Select_CH3();
adc_values[3] = HAL_ADC_GetValue(&hadc1);
HAL_Delay(100);
ADC_Select_CH4();
adc_values[4] = HAL_ADC_GetValue(&hadc1);
HAL_Delay(100);
ADC_Select_CH5();
adc_values[5] = HAL_ADC_GetValue(&hadc1);
HAL_Delay(100);
printf("IN 4 = H1:21 = %d\n\r",adc_values[0]);
printf("IN 9 = H2:7 = %d\n\r",adc_values[1]);
printf("IN 13 = H2:15 = %d\n\r",adc_values[2]);
printf("IN 14 = H2:17 = %d\n\r",adc_values[3]);
printf("IN 15 = H2:19 = %d\n\r",adc_values[4]);
printf("IN 16 = H2:21 = %d\n\r",adc_values[5]);
printf("\nFinished ADC Conversion for all channels\r\n");
HAL_Delay(2000);
only IN 16 shows 0 and 4095 when connected to GND and Vdd. All other channels showing unexpected values - around 3500 for Vdd and around 1500 for GND. What could be a problem ? ADC_Select functions are these - always rank 1:
void ADC_Select_CH0 (void)
/** Configure for the selected ADC regular channel its corresponding rank in the sequencer and its sample time.
sConfig.Channel = ADC_CHANNEL_4;
sConfig.Rank = 1;
sConfig.SamplingTime = ADC_SAMPLETIME_47CYCLES_5;
if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
printf("govance");
Error_Handler();
void ADC_Select_CH1 (void)
sConfig.Channel = ADC_CHANNEL_9;
sConfig.Rank = 1;
Error_Handler();
void ADC_Select_CH2 (void)
sConfig.Channel = ADC_CHANNEL_13;
sConfig.Rank = 1;
Error_Handler();
void ADC_Select_CH3 (void)
sConfig.Channel = ADC_CHANNEL_14;
sConfig.Rank = 1;
Error_Handler();
void ADC_Select_CH4 (void)
sConfig.Channel = ADC_CHANNEL_15;
sConfig.Rank = 1;
Error_Handler();
void ADC_Select_CH5 (void)
sConfig.Channel = ADC_CHANNEL_16;
sConfig.Rank = 1;
Error_Handler();
My ADC Init function is here:
static void MX_ADC1_Init(void)
/* USER CODE BEGIN ADC1_Init 0 */
/* USER CODE END ADC1_Init 0 */
/* USER CODE BEGIN ADC1_Init 1 */
/* USER CODE END ADC1_Init 1 */
/** Common config
hadc1.Instance = ADC1;
hadc1.Init.ClockPrescaler = ADC_CLOCK_ASYNC_DIV16;
hadc1.Init.Resolution = ADC_RESOLUTION_12B;
hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
hadc1.Init.ScanConvMode = ADC_SCAN_ENABLE;
hadc1.Init.EOCSelection = ADC_EOC_SEQ_CONV;
hadc1.Init.LowPowerAutoWait = DISABLE;
hadc1.Init.ContinuousConvMode = ENABLE;
hadc1.Init.NbrOfConversion = 6;
hadc1.Init.DiscontinuousConvMode = DISABLE;
hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE;
hadc1.Init.DMAContinuousRequests = DISABLE;
hadc1.Init.Overrun = ADC_OVR_DATA_PRESERVED;
hadc1.Init.OversamplingMode = DISABLE;
if (HAL_ADC_Init(&hadc1) != HAL_OK)
Error_Handler();
/** Configure Regular Channel
// sConfig.Channel = ADC_CHANNEL_4;
// sConfig.Rank = ADC_REGULAR_RANK_1;
// sConfig.SamplingTime = ADC_SAMPLETIME_247CYCLES_5;
// sConfig.SingleDiff = ADC_SINGLE_ENDED;
// sConfig.OffsetNumber = ADC_OFFSET_NONE;
// sConfig.Offset = 0;
// if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
// Error_Handler();
// /** Configure Regular Channel
// sConfig.Channel = ADC_CHANNEL_9;
// sConfig.Rank = ADC_REGULAR_RANK_2;
// Error_Handler();
// sConfig.Channel = ADC_CHANNEL_13;
// sConfig.Rank = ADC_REGULAR_RANK_3;
// Error_Handler();
// sConfig.Channel = ADC_CHANNEL_14;
// sConfig.Rank = ADC_REGULAR_RANK_4;
// Error_Handler();
// sConfig.Channel = ADC_CHANNEL_15;
// sConfig.Rank = ADC_REGULAR_RANK_5;
// Error_Handler();
// sConfig.Channel = ADC_CHANNEL_16;
// sConfig.Rank = ADC_REGULAR_RANK_6;
// Error_Handler();
/* USER CODE BEGIN ADC1_Init 2 */
/* USER CODE END ADC1_Init 2 */
Any advice is really appreciated, thank you very much!
2024-11-10 1:04 PM
Thank you very much for your replay,
Yes, I changed my code to this:
void ADC_Select_Channel(uint32_t channel, uint16_t *result)
sConfig.Channel = channel;
sConfig.SamplingTime = ADC_SAMPLETIME_12CYCLES_5;
sConfig.Offset = 0;
Error_Handler();
uint32_t sum = 0;
for (int i = 0; i < 3; i++)
if (HAL_ADC_PollForConversion(&hadc1, 100) == HAL_OK)
sum += HAL_ADC_GetValue(&hadc1);
else
printf("ADC Polling Error on channel %lu\r\n", channel);
Error_Handler();
//HAL_Delay(10); // Pauza između mjerenja
*result = sum / 3; // Spremi srednju vrijednost
void Measure_All_Channels(void)
uint16_t result_CH0, result_CH1, result_CH2, result_CH3, result_CH4, result_CH5, result_CH6;
ADC_Select_Channel(ADC_CHANNEL_4, &result_CH0);
printf("Channel 0 Average Value: %u\r\n", result_CH0);
ADC_Select_Channel(ADC_CHANNEL_9, &result_CH1);
printf("Channel 1 Average Value: %u\r\n", result_CH1);
ADC_Select_Channel(ADC_CHANNEL_13, &result_CH2);
printf("Channel 2 Average Value: %u\r\n", result_CH2);
ADC_Select_Channel(ADC_CHANNEL_14, &result_CH3);
printf("Channel 3 Average Value: %u\r\n", result_CH3);
ADC_Select_Channel(ADC_CHANNEL_15, &result_CH4);
printf("Channel 4 Average Value: %u\r\n", result_CH4);
ADC_Select_Channel(ADC_CHANNEL_16, &result_CH5);
printf("Channel 5 Average Value: %u\r\n", result_CH5);
printf("------------------------\n");
}and it works OK in this most simplistic way. I tried also a Scan Conversion Mode but I didn't succeed.
And with DMA usage my main loop stops to iterate...
2024-11-08 12:15 PM
You don't check the HAL status when you call HAL_ADC_PollForConversion. So how do you know if it return HAL_OK, HAL_ERROR or HAL_TIMEOUT?
2024-11-10 11:34 AM
What hardware is this, your own or a "known good" board like Nucleo or Disco?
How exactly are you "connecting the pins to GND or VCC", via a resistor or directly?
Read out and check/compare-to-working/post ADC and relevant GPIO registers content.
2024-11-10 1:04 PM
sConfig.Offset = 0;
Error_Handler();
uint32_t sum = 0;
else
Error_Handler();
2024-11-10 1:10 PM
Thank you very much for your reply!
I finally made it with the code I posted in earlier reply.
I use my own board and connecting pins to GND and VCC directly - but it works ok now except Scan Conversion Mode. I obviously don't know how to do it... More studying to come.
2024-11-14 5:26 AM
Hello @tompa
For the scan mode you can refer to this LL example on STM32F411-Nucleo board.
