2025-08-06 5:51 AM - edited 2025-08-06 5:52 AM
hi iam having nucleoh755 board, in that when i try to flash target is not connecting and when not connecting to cube programmer also, it showing perform discovery using debug authentication. how to do it. please find the image for the error shown. and MCU power supply all are ok.
regards,
srinath
2025-08-06 6:14 AM
hi @Imen.DImen.D thanks for the response, my problem has solved, i dont know how, when connecting to cube programmer i have changed to power down mode and target has connected, and i have erased the chip, after that it is fine. working normally.
regards,
srinath
2025-08-06 6:09 AM
Hello @Srinath_03 ,
Please follow these articles which may help you:
2025-08-06 6:14 AM
regards,
srinath
2025-08-06 6:23 AM
Hi @Srinath_03 ,
Good to hear you made it work and thanks for sharing your progress on this.
2025-08-06 6:36 AM
hi @Imen.D thanks,
but i want to know what makes the mcu to go in that mode, i dont know fault problem, and why target not found issue came. mcu power supply are ok only, other than that what can cause the mcu to go that mode.
regards,
srinath
