2018-04-16 7:47 AM
I need the pcb project for STM32F746 Discovery. I have the schematics, BOM, gerbers but the pcb project. Can I find it somewhere?
Thanks,
Denin
#pcb-project #stm32f746-discovery2018-04-16 8:04 AM
You should discuss with your local ST representative or FAE if the materials are available and under what conditions.
2018-04-16 8:15 AM
Look file en.stm32f746g-disco_sch.zip at st.com
2018-04-16 11:43 AM
Haven't checked what exactly is covered in the CADSTAR files, and I'd likely assume you're using something else.
2018-04-16 11:05 PM
I have already checked the folder given at the link. The pcb file given there cannot be opened by Altium, or I could not have managed to. Is there a way of doing so?
2018-04-17 5:33 AM
If the format is not directly loadable then you will need to Import or Translate, or get a CADSTAR viewer.
2018-04-20 7:00 AM
Thank you very much. It's Altium's bad. Has been solved.
