2024-02-22 8:35 AM
I am using the NUCLEO-G071RB and the X-NUCLEO-DRP1M1 with the X-CUBE TXPP Software Bundle.
I created my project via the instructions from https://wiki.st.com/stm32mcu/wiki/STM32StepByStep:Getting_started_with_USB-Power_Delivery_Dual_Role.
Everything works fine.
I have a case where my device is always a sink but has to change Data Role. Is there a way to read the data role via the stack? I know that there is a defualt power role, which basically sets the Data Role ( Sink = UFP). And if there is a Data Role Swap Request I could just chnge my variable.Depending ont he Data Role I need to set a ID.
But is there a "nicer" way to read the Data Role from the Stack?
Thanks in advance.
2024-02-28 4:10 AM
you should be able to extract the current data role from the variable DPM_Params[PortNum].PE_DataRole. Usually the PortNum is 0, unless you have multiple ports. This value is automatically updated by the stack.
The parent structure array (DPM_Params) is defined in usbpd_dpm_core.c file.
When the requested data role swap is finished (acknowledged by the other side), the USBPD_DPM_Notification (defined in usbpd_dpm_user.c) is called with value USBPD_NOTIFY_DATAROLESWAP_UFP or USBPD_NOTIFY_DATAROLESWAP_DFP, depending on the new role.
Best regards,
Adam Berlinger
2024-02-23 4:11 PM
Hello @VH ,
There has been a case created to resolve this question and we will be reaching out to you directly.
Regards,
Roger
2024-02-28 4:10 AM
Best regards,
Adam Berlinger
