Hello, We have some problem on part number STM32H743XIH6. After we opened the pack to checking the parts condition. We found out the bottom side have some white texture color on PCB. Is it normal condition? Can we use them? Thanks Man
Manman
Associate III
4 REPLIES 4
FBL
Hello @Manman​
Honestly, the quality of the image is not high enough to see. Could you please provide high quality photo? Otherwise, you may need to contact your Local ST.
Thank you for your contribution.
Best regards,
FBL
My guess would be that it's residue from a wash or cleaning process. ​Probably something that's Green and doesn't use harsh forever chemicals..
You'd probably need to determine if this interferes with your soldering process or not. I'd expect your inbound inspection or manufacturing guys would be able to determine if this was workable / acceptable ​
Manman
Associate III
Hello F.Belaid,
Yes, we can provide the clear photo. Please find the attach. All the parts was new but we found out some issue on PCB. It look like a scratches and contamination. About the BGA quaility is no problem. Is it normal standard and no affect?
Thanks
Man
Dear @Manman​,
I escalated the issue internally. I hope we will get back to you as soon as possible. Thank you.
Best regards,
FBL
