2025-01-20 8:48 PM
what's the problem, when i connect heater ATX with the relay on PCB, the process receives a external interrupt and it stops the timer 1 and also stops the process, while the other timer which is timer5 works fine but when disconnect heater form the PCB, it works fine and also relay switches normally as i want to.
2025-01-21 12:45 AM
You need to give more details - see How to write your question to maximize your chances to find a solution
Remember that we know absolutely nothing about your project other than what you give in your post.
PS
And don't forget to mark the solution on your previous thread:
