2026-03-05 1:29 AM - last edited on 2026-03-05 2:22 AM by Peter BENSCH
Is there any alternative of "B-CAMS-OMV" to use with "STM32F746G-DISCOVERY" as in my region it is not available and the cost will be huge if I want to ship it to Bangladesh. So, is there any alternative modules that I can search for?
2026-03-05 2:21 AM
Welcome @alaraf, to the community!
You could search for:
OV5640 (5Mpx) OMV camera modules (OpenMV-style)
OV2640 (2Mpx) or OV7725 (VGA) OMV camera modules
Hopefully, your preferred search engine will find suggestions from your region. Just double‑check the 30‑pin OMV pinout (DCMI lines, XCLK, I²C, PWDN, RESET, 3.3V, GND) for mechanical and electrical compatibility.
Hope that helps?
/Peter
2026-03-11 2:54 AM
can you check if you can order STM32F4DIS-CAM? it may be compatible with the B-CAM-OMV.
