2023-03-23 5:09 AM
I am using ST25DV64KC and ST25PC-NFC v 2.61 on my pc with windows 10. The software opens just for few seconds and then closes by itself. I have installed it thrice. I tried restarting my pc as well but nothing helped. Kindly let me know what can i do to use the software. Thank you.
2023-03-24 9:45 AM
this error comes from a conflict between the different DLLs installed by Windows. In some versions of Windows 10, DLLs necessary for the ST25PC SW application are missing.
Please download and install the Visual C++ Redistributable Packages for Visual Studio 2013
https://www.microsoft.com/en-us/download/details.aspx?id=40784
This will correct crash issue.
Best regards,
NFC Customer Support
2023-03-24 9:45 AM
Best regards,
2023-03-24 11:00 AM
2023-03-27 12:20 AM
to use the ST25PC SW, you will need a RF NFC reader such as ST25R3911B-DISCO or ST25R3916-DISCO.
For your information, the ST25DV64KC-DISCO is a kit based on STM32 Nucleo board and a ST25DV64K dynamic tag to demonstrate the usage of ST25DV64K communication with the STM32 through I2C and also communication through RF.
To play with ST25DV64K-DISCO kit through RF, you can use the ST25PC SW with one of this reader, you can also use the ST Android apps (ST NFC Taps) or the iPhone compatible apps (NFC Tap).
Best regards,
NFC Customer support
2023-04-03 9:15 AM
2023-04-03 10:08 AM
can you please create a new thread with all this question related to ST25DV64KC board (and not PC SW crash) and the correct title related to ST25DV64KC board ? With this new thread, I could direct you to the customer support which takes care of this subject.
Best regards,
