2025-06-06 1:03 AM
Hi Team,
I have purchased the STEVAL-25R200SA board. I would like to know if I can develop custom NFC features using this board. And please provide me with sample NFC application code suitable for this board to refer to.
Thank you
Sreevishakh
2025-06-06 1:17 AM
See the Product Page for Documentation and supporting Tools & Software; Schematics, etc, are on the CAD Resources tab.
See also https://www.st.com/en/nfc/st25-nfc-readers.html? for general information & resources for the ST25 family
And the Product Page for the specific ST25R200 device: https://www.st.com/en/nfc/st25r200.html
2025-06-06 1:17 AM
2025-06-06 1:33 AM
Hi Andrew Neil,
Thank you for your prompt replay,
I could not find any sample NFC application code from the links. Can you please help me to get it?
2025-06-06 1:36 AM
Look on the Tools & Software tabs of both the Kit and the chip Prudct Pages.
2025-06-06 4:16 AM
the STEVAL-25R200SA runs a FW (sources available in STSW-ST25R020) and is controlled by a PC GUI (available in STSW-ST25R019) over the STLink Virtual Communication Port. The PC GUI includes a Reader+Tag demo tab that can be used to run the STEVAL-25R200SA in standalone mode and to react on some events (e.g. switch on a LED when a tag is detected). This can be used to prototype embedded custom applications. See the related User Manual UM3364 (ST25R200 Eval GUI for the STEVAL-25R200SA kit). Custom applications can also be developed on PC side over the serial link API. Feel free to provide more information about your custom application.
Rgds
BT
2025-06-08 9:54 PM
Hi Brian,
Thank you for your support.
I found the firmware from the Link - STSW-ST25R020, and it is an executable file not able to file source files. As you mentioned, this board can be used to prototype embedded custom applications [access control application]. Are there any sample NFC application codes available for STEVAL-25R200SA? me to refer to Kickstart, as I am new to NFC technology.
Best Regards
Sreevishakh
2025-06-09 12:22 AM
the package STSW-ST25R020 contains the executable STEVAL-25R200A-FW-v1.0.0.exe. This executable installs the source code after you accept the licensing terms.
Rgds
BT
2025-06-09 10:47 PM
Thank you Brian,
I will work on your inputs.
