2013-07-30 7:09 AM
Hello
I try to find out the difference between Reader Application M24LR04E and Reader Application M24LR16E when it comes to data reading. As far as I understood both components (M24LR04E and M24LR16E) operate with identic commands. In my case I only want to read data from block 0x000 to 0x00F. On both components exist the requested memory range. Further I do not use any password protection. When I read data from M24LR16E with Reader Application M24LR04E all what I get back is just ''no Tag answer''. Why only M24LR16E works with Reader Application M24LR16E and not with Reader Application M24LR04E? Where is the difference?Solved! Go to Solution.
2013-08-01 8:38 AM
Concening the adress for different density devices, might you tell me if the following AN help you ??
Both M24LR04E & M24LR16E shall work with DEMOKIT-M24LR-A (is it the kit you are using?)
Are you using them in addressed mode?
Thanks a lot,
Have a nice day, All the best, ST dynamic NFC/RFID tag supportP.S : Concerning protection mechanism , please see AN 3002 http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/CD00239158.pdf
More AN on2013-08-01 8:38 AM
Thanks a lot,
More AN onWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
