2013-04-19 7:10 AM
Do you have reference of coil antennas which we can used with the M24LRxxx?
#antenna #ant3 #inductorSolved! Go to Solution.
2013-04-19 7:28 AM
Dear Customer,
Thanks a lot for your interest in our product,You will find on the file attached, the inductors that we have used & testedfor our designs.
There are Bourns’s inductors:
Inductor 45 37478E2Adpdf
Inductor 58 4407893Adpdf
5.8 mm diameter
Inductor 78 18BF1B7Cdpdf
7.8 mm diameter
# It is this one that is used on our ANT3-M24LR-A reference antenna.
Inductor 98 429D885Fdpdf
9.8 mm diameter
And here the reference from ABC :
SR08054R7MLB
SR06044R7MLB
Here below some reference that we do not have tested yet :
Premo antenna : Thanks a lot, Yours faithfully, ST Online SupportFrom: gourdou.yvon.001
Posted: Friday, April 19, 2013 4:10 PM Subject: Coil antenna referenceDo you have reference of coil antennas which we can used with the M24LRxxx?
________________ Attachments : Inductor_45_37478E2Ad01.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htyv&d=%2Fa%2F0X0000000aat%2FhaNqSJA5xDGpFmuyqCxwfol5wq1g99Oscml_6jbcJ1g&asPdf=falseInductor_58_4407893Ad01.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htz0&d=%2Fa%2F0X0000000aau%2FoCtkQgnhv7Liac2sW9gE7j9h1ZkNcW60Z5nfjR_jYAU&asPdf=falseInductor_78_18BF1B7Cd01.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtsK&d=%2Fa%2F0X0000000aYD%2FYH7Qa8Ibno1QlyFJ5hy6GIsVqyec9_tIVNxndtLLqHs&asPdf=falseInductor_98_429D885Fd01.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtrS&d=%2Fa%2F0X0000000aY1%2FumbouYJpwysMcvzNtjWvWUC8KGcppGOHY1_lxTDSCoU&asPdf=falseSR0604-L-___.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtkH&d=%2Fa%2F0X0000000aWT%2FXPhJ9Q3FWtjYzCL6AQnCJ_dfq4fJmY.dOBIIhNL3enM&asPdf=falseSR0805-L-___.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htz5&d=%2Fa%2F0X0000000aav%2Fj2VgWemQqXPVdG5RGkgyrA_T1.NyGzQbAJtSLAVqtQE&asPdf=false2013-04-19 7:28 AM
Dear Customer,
5.8 mm diameter
7.8 mm diameter
9.8 mm diameter
SR08054R7MLB
SR06044R7MLB
________________ Attachments : Inductor_45_37478E2Ad01.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htyv&d=%2Fa%2F0X0000000aat%2FhaNqSJA5xDGpFmuyqCxwfol5wq1g99Oscml_6jbcJ1g&asPdf=falseInductor_58_4407893Ad01.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htz0&d=%2Fa%2F0X0000000aau%2FoCtkQgnhv7Liac2sW9gE7j9h1ZkNcW60Z5nfjR_jYAU&asPdf=falseInductor_78_18BF1B7Cd01.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtsK&d=%2Fa%2F0X0000000aYD%2FYH7Qa8Ibno1QlyFJ5hy6GIsVqyec9_tIVNxndtLLqHs&asPdf=falseInductor_98_429D885Fd01.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtrS&d=%2Fa%2F0X0000000aY1%2FumbouYJpwysMcvzNtjWvWUC8KGcppGOHY1_lxTDSCoU&asPdf=falseSR0604-L-___.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HtkH&d=%2Fa%2F0X0000000aWT%2FXPhJ9Q3FWtjYzCL6AQnCJ_dfq4fJmY.dOBIIhNL3enM&asPdf=falseSR0805-L-___.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006Htz5&d=%2Fa%2F0X0000000aav%2Fj2VgWemQqXPVdG5RGkgyrA_T1.NyGzQbAJtSLAVqtQE&asPdf=false2013-07-22 2:37 AM
I'd like to know if the coil antenna on the ANT3-M24LR-A and the ANT3-M24LR04E are the same ? Thank you2013-07-22 6:52 AM
yes, they are the same. Best regards, Dynamic NFC/RFID tag supportWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
