2021-12-17 12:28 PM
We are developing both an Android and iOS app that leverages FTM from the ST25DV chip.
In the Android version of the NFC Tap app, we can send custom commands and interact with FTM. However, in the iOS app, there is no "send custom command" screen. I know in iOS there is a section for FTM where you can send pictures and files, but why is this functionality missing from the iOS app.
More to the point... Can we send custom commands in iOS that leverages FTM mode? Our iOS developer has been struggling for months to get this to work. Can someone please confirm that sending custom commands and FTM is supported in iOS.
Thanks in advance.
Mariano
2022-02-18 12:24 AM
Hi Mariano,
I agree with you for the 2 suggestions : I will include them into dev for next iOS NFC Tap release that should be delivered in March. . At least for iOS...
I forward your request to our Android Team.
glad to hear you that FTM is understood in iOS.
Br,
2022-02-17 9:06 AM
Hi again MFerr,
Please, have a look into V3.9 iOS NFC Tap Release : https://www.st.com/content/st_com/en/products/embedded-software/st25-nfc-rfid-software/stsw-st25ios001.html
We have updated the iOS NFC Tap with the possibility to send custom command in "coreNFC" submenu, with the custom code and custom parameters.
Unfortunately, we only display command return status after execution. We "re delivering a new release in next few days displaying data received.
Please, as we re in dev process , we still have time to implement something missing if needed. Let me know.
Regarding FTM, I don't catch your point : FTM is already supported in iOS NFC tap with multiple use cases (Data transfer , picture up/down load, FW update, ...). Please , could you clarify more ?
Thx and br
2022-02-17 10:54 AM
Hi Victor,
Thank you for the response and it is great to hear that the NFC Tap app now supports sending custom commands. We have been using the Android version quite extensively (We even hacked the open source version to tailor the screens and functionality to our needs). Based on the Android app, I would graciously suggest the following improvements in order of priority:
Those would be my two suggestions for both Android and iOS. We also noticed in Android, if you send a custom command with lower case characters, that we receive an error. This may be an issue specific to our firmware implementation, but I thought I would mention it. It took a while to figure that out.
Finally regarding FTM, I now understand it works with iOS. Please disregard this question.
Thanks,
Mariano
2022-02-18 12:24 AM
Hi Mariano,
Br,
