2020-06-25 4:00 AM
2020-07-03 2:38 AM
You can try waking up the board using Hercules software. The DTR and RST pin needs to be enabled alternatively to Wake up the device. When the board is connected to PC it will be in boot mode. By Turning On DTR pin and Toggling RST pin will wake up the board.
To get the tag details through uart one way is you have to give the commands to read tags from PC through USB to uart (in build in eval board). Other way is to modify the firmware they have given.
2020-07-03 2:38 AM
