2013-11-24 9:19 AM
I use
the CR95HF
chip
for
reading and
writing data
in the
NFC
forumtag
Type 2
Tag
NTAG203F
).I can
read the
data,
but
can not write data to Tag,although
NTAG203F
is writable
.When I
send
a command to
write
data
, the responseI get from
the
CR95HF is
0x90
0x50
0x80
0x01
0x22
0x00
0x00
.In
dataseet
for
CR95HF(Doc ID 018669 Rev 2) I
can not understand
what does mean
Result
code
0x90
? Please, could you explain me response from CR95HF. Best regards, Nenad #cr95hfSolved! Go to Solution.
2013-11-30 11:37 AM
When the tag responds correctly :
the response has CR95HF header 0x80when it is incorrect (wrong CRC, insufficient data received),
->generated the header 0x90 and the packet format is equal to 0x80 (0x90, len, data, status+collision report )
The report 0x90 is reserved for ACK or NAK
I hope this is helping you, ST NFC/RFID dynamic supportFrom: mitic.nenad
Posted: Sunday, November 24, 2013 6:19 PMSubject: CR95HF Write commandI use
the CR95HF
chip
for
reading and
writing data
in the
NFC
forumtag
Type 2
Tag
NTAG203F).I can
read the
data,
but
NTAG203F
is writable
.When I
send
a command to
write
data
the
CR95HF is
0x90
0x50
0x80
0x01
0x22
0x00
0x00
.In
dataseet
for
can not understand
what does mean
Result
code
0x90
? Please, could you explain me response from CR95HF. Best regards, Nenad2013-11-30 11:37 AM
the CR95HF
chip
for
reading and
writing data
in the
NFC
forumtag
Type 2
Tag
NTAG203F).I can
read the
data,
but
NTAG203F
is writable
.When I
send
a command to
write
data
the
CR95HF is
0x90
0x50
0x80
0x01
0x22
0x00
0x00
.In
dataseet
for
can not understand
what does mean
Result
code
0x90
? Please, could you explain me response from CR95HF. Best regards, NenadWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
